Glowforge Air Filter Won't Turn On
If your Air Filter doesn't turn on when you flip the switch, and the power indicator doesn't light up, you may need to replace the fuse. We've included a free spare fuse with your Air Filter. Here's how to install it.
How to replace the Air Filter fuse
  1. Turn off and unplug your Air Filter.
  2. Remove and replace the fuse next to power switch. Please refer to the following image:
    An image sequence of a screwdriver being used to open a comparment near the air filter power switch, remove an old fuse and insert a new fuse.
    1. Turn off the power and pry up the fuse grove below the power switch with a screwdriver.
    2. Inside, you'll find the burnt out fuse in a clip, and a spare fuse in a cylindrical housing
    3. Remove the damaged fuse from the clip with a screwdriver, and slide the spare fuse out of the cylindrical housing.
    4. Insert the spare fuse into the clip.
    5. Slide the fuse block back into the hole next to the power switch, and you're all set!
If have any questions, please contact Glowforge Support.
Was this article helpful?
