Clean your Air Filter
To clean your Air Filter, start by turning it off and unplugging it. Make sure it's closed; you shouldn't be cleaning the inside. All exterior surfaces can be cleaned with a rag dampened with isopropyl alcohol.
Do not spray liquids on the Air filter, as they may seep inside.
Moving your Air Filter
No matter how far you're moving your Air Filter, you must use the original packaging materials, and it cannot be shipped safely without the original packaging materials.
To move your Air Filter, turn it off and disconnect the power cord. Disconnect the exhaust hose and hose clamp from the lid. Re-pack in the original packaging.
