Save, Undo, Store, Export, Sort, and Search Designs
Save and Undo
When you create and edit a design in the Glowforge App, your changes are automatically and instantly saved as you make them. (No save button necessary!) If you close your browser, navigate to another page, or just hit refresh, your work will pick up right where you left off.
Here are some tips if you need to undo or start over
  • If you make a change by mistake, you can use the Undo button in the workspace to go back to earlier versions. You can undo your changes until you close or refresh the page.
  • Catalog designs can be reset. If you want to remove all your changes, click on the three-dot More menu, then click Design Details, and then Reset Design.
  • Designs that you upload cannot be reset, but you can upload them a second time for a fresh copy.
Store, Export and Save
If you subscribe to Glowforge Premium, you have unlimited storage for as long as your subscription remains active.
Otherwise, designs you’ve opened within the last 30 days are stored. Keep the original file on your computer, or export and save it to your computer when your design is finished, so you don’t lose your work after 30 days. (Catalog designs you own are always stored in your Dashboard.)
In the My Designs library, when you point to a design that is nearing 30 days of inactivity and about to be removed, you will see an inactive alert. If you want to use that design in the future, you can do one or both of these things:
  • Open the design to keep it active for another 30 days.
  • Export and save the design.
You can also export and save designs to your computer so you can edit them in other design software, such as Inkscape, Adobe Illustrator, Lightburn, xTool and Creative Space.
To export and save a design
  1. Go to the Glowforge App (https://app.glowforge.com/) and sign in.
  2. From the Dashboard, go to the My Designs library and click on the design you want to save.
  3. When the design opens:
-If you have a Glowforge and you are previewing the bed image: Click the 3 dot More menu, and select Export Design
-If you are in the Design view where you have a canvas background:  Click the Export button on the top right.
4. Choose your export format:
- SVG — Compatible with most design and laser software, including Inkscape, Adobe   Illustrator, LightBurn, RDWorks, and LaserGRBL.
- Lightburn (.lbrn) — Opens directly in LightBurn, a laser control application.
- xTool Creative Space (.xcs) — Opens directly in xTool Creative Space for xTool laser owners.
5. For multi-part designs, you can select which parts of the design to include in the export.
6. The design is automatically saved and downloaded to your computer.
Notes
  • When you export a design, the file includes any designs that you uploaded, images that you traced, and any artwork and graphics that you inserted using the Premium Creative tools. Your settings will be added to the saved file as readable text, too. That means when you're ready to print it, you can reference the settings from the file.
    - When you export a Catalog design, the export will include any added artwork and settings. Exported catalog design are tracked. You may create physical prints of Catalog designs, but may not sell, share, or redistribute the digital design file.
    - Using exported files with non-Glowforge lasers: If you don't own a Glowforge, export is your primary way to get designs onto your laser. After exporting, open the file in your laser's software (such as LightBurn, xTool Creative Space, RDWorks, or LaserGRBL) to configure hardware-specific settings like power, speed, and number of passes, then print from there.
Sort and Search
Once you have worked with multiple designs, there will be more than can fit on one page in the Dashboard. By default, your designs are sorted by the last opened date, so that you can see your most recent prints first.
To help find other designs you're looking for, you can also sort designs by the last opened or created date, or search your designs by name.
To sort or search for designs
Recent Designs
  • On the Dashboard, you will see your seven most recent designs in the middle of the page, in the Recent Design section. To see more designs, click the View All button on the right of that row. The page will refresh and display all of your designs. The order of this page can be changed by clicking the Sort By dropdown menu in the top, right corner.
My Designs
  • - On the Dashboard, click the My designs link in the left sidebar menu. The page will refresh and display all of your design. The order of this page can be changed by clicking the Sort By dropdown menu in the top, right corner.
Search by Name
  •  If you know the name of your design, you can enter it into the Search designs box on the left hand sidebar menu, then hit enter to search.
See also
