Handle Locks - Remove and Replace
Some Glowforge printer packages include white handle locks. They can be removed, and here we'll show you how. (If you're moving your Glowforge and can't find the handles, you can tape over the holes instead.)
How to remove the handle locks
  1. The four (4) handle locks are on the bottom of your box.
    The box a Glowforge arrives in, with arrows pointing to the white plastic handles near the corners of the box.
  2. Hold the white tab on the right side of each white box handle.
    A and holding the plastic tab on the right side of the handle
  3. Pull each white tab from right to left, opening the handle like a door.
    A hand using the tab on the right side to open the handle
  4. Gently pull the frame of the handle to remove it from the box.
    A hand grasping the frame of the white plastic handle
  5. Keep all four (4) locks. They lock the box together and are required for proper shipping of your Glowforge.
    4 handle locks arranged on top of the Glowforge shipping box
How to replace the handle locks
  1. After following the packaging instructions, gather your four (4) white handle locks.
  2. Use the pull tab to open all four (4) handles. Position the two back flaps so they face directly inside the box.
    One hand holding a handle lock by its frameTwo hands folding the flaps of a handle lock inward
  3. Insert all four (4) locks so they sit flush against the outer box. Use your finger to gently lock the inner tabs down and up into their final position.
    One hand holding the frame of the handle lock, the other folding the bottom tab towards the inside of the boxOne hand holding the frame of the handle lock, the other folding the top tab towards the inside of the box
  4. Close the securing handle door and press to ensure it is locked in place. Your packaging is now locked together and ready to travel.
    A hand holding the tab on the right side of the handle lockA hand using the index finger to push the tab on the right side of the handle lock into place
If have any questions, please contact Glowforge Support.
