Adjust the Carriage Plate Belt Tension
Glowforge Basic/Plus/Pro
Under the laser arm, a belt attaches to the carriage plate and moves the printer head to the left and right. To replace the carriage plate belt, follow the instructions here.
Once it's installed, you'll need to adjust the belt tension using a 3mm hex key (as shown below). Here's how to do that.
An image of a 3mm hex key tool
  1. Turn off and unplug your Glowforge
    Turn off your Glowforge, unplug it, and open the front door. Carefully remove the crumb tray.
  2. Locate the laser arm pulley
    Without removing the carriage plate and belt, locate the black pulley fastened by a metal screw on the right end of the laser arm.
    Image: The pulley on the right side of the laser arm. The crumb tray has been removed.
  3. Insert the hex key into the pulley
    Insert the short side of the 3mm hex L-key into the metal screw with the long handle pointing toward the front of the unit.
    Image: The hex key is in the pulley ready to loosen the screw
  4. Loosen the pulley
    Turn the key clockwise to loosen the screw until the pulley can slide with some friction. Don’t remove the key from the screw.
  5. Slide the pulley to the right
    Holding the key with your one hand, position your other hand to push the pulley to the right until the belt is fully extended.Image: One hand holds the pulley in place, while the other holds the hex key.
  6. Tighten the pulley
    While keeping tension with your other hand, turn the hex key counter-clockwise to tighten the screw in the pulley.
  7. Check the belt tension
    When pressing lightly on one side of the belt, the other side should not move. It may take a few tries to get the belt tension correct. If the belt has too much slack, loosen the pulley and try again.Animated image of a finger pushing on the carriage plate belt. Only the side being pushed moves
  8. Try a test print.
    When you are satisfied with the tension on the belt, plug in your Glowforge, turn it on, and try a test print.
If you have any trouble, please reach out to our team and we'll be happy to help!
